RCU Forums - View Single Post - firebird commander 2 trouble for noob
Old 08-08-2006 | 06:06 AM
aeajr's Avatar
aeajr
Default RE: firebird commander 2 trouble for noob
A critical piece of advice to you and to all two channel pilots. Respect the
wind! REALLY RESPECT THE WIND!!!!!
These planes either have throttle and rudder or throttle and differential
thrust, which does about the same thing.
If you fly on a windy day you have a very high probability of losing the
plane. Why, because you have no way to fight the wind. If the plane gets
down wind from you, and it will, here is what happens. You hit the power to
fight the wind, but these planes climb when you hit the power, so instead of
coming back to you, they climb and as they climb, the wind pushes the plane
further away.
A very very experience two channel pilot can work around this through a series
of maneuvers called the death spiral. However, this is a difficult thing to
control for a new pilot. There is a fellow in our club who has lost two
Firebird Commanders to the wind. We finally convinced him to get an Aerobird.
A three channel plane with elevator control can push the nose down and dive
into the wind to come back. This is how gliders can fly against the wind
without motors.
So, don't fly your rudder/throttle or diff thrust plane in wind over 5 MPH
until you are very good with the plane. Don't get over 7 MPH until you can
easily fight your way back from a down wind position.
TIP
I don't know if this works for that Outlaw or the Scout, but for the Firebird,
II, sT, XL,
Fighterbird and Commander, if you put a popsicle stick under the back of the
wing, it lowers the angle of attack of the wing and the plane will not climb
as much on power application. If you learn to manage the plane well, this can
give you better penetration into the wind, but it still will not let you put
the nose down into the wind.
Enjoy these planes but remember, they are best flown in little to no wind.
