RCU Forums - View Single Post - Walbro Problem
Old 08-08-2006 | 10:27 AM
Tired Old Man
Default RE: Walbro Problem
Vapor lock is simply the fuel in the line getting hot enough to convert to a gaseous state either just before or just after entering the carb. The fuel is there, but not in a usable quantity. Choking draws additional fuel into the carb, removing the issue. Look to see if there is a way to let cool air circulate near the fuel lines and carb after landing. A good check to see if that's the problem would be to do as you noted and remove the cowl for a flight to see if the problem continues.
