RE: Substitute for Ether
With a glow plug equipped diesel you could start it on glow and switch it to diesel after it warms up. Need a fuel filler hooked up so when in the fueling position the carb will draw from an outside glow bottle and when shut it draws from the diesel flight tank. Use a fuel dot to fill the flight tank.
