Originally posted by Glorfindel
I'm very happy to discover (in fact i red it here
) that aeropoxy is Hysol 9462 wich is realy easy to get at a cheaper price from a Loctight dealer.
Do i realy need a gun to use it or i can use the old good wood mix stick???
Thx
Well you can mix any epoxy with the good old Popsicle sticks, but there are times when a long nozzle is so much easier to apply a small fine bead of aeropoxy just in the right spots. The shorter nozzle is handy also in tight closer spots. My opinion is buy the gun and some nozzle's you'll find they come in handy. The most important thing I've found is planning! Plan & setup several items that need the aeropoxy and do them all at the same time. Then put the nozzle in the freezer and you can use it again several times. One long and one short was all I needed for my entire Bob Cat ---------
Lee H. DeMary
AMA 36099
