RE: CMPro Swallow EX 90
Dear Tim & Rendegade,
Thanks a lot for your information. Kindly also tell us regarding;
1. Did you fuel proof the engine compartment?
2. Are you using Y pushrods on elevators or some assembly to avoid differentials
3. Where did you place the batteries?
4. Is 170mm from LE is the best CG point??
5. How about its knife edge hold??
6. Nose tracking in a loop??
7. Is .90 Size 2 stroke enough to pull un limited verticals or pipe required??
Awaiting your reply!!
Regards,
Sunny.
