well, i tried tightnening again but still a small leak from one place, also the clutch seems to be slipping again, this is prob due to the reason why i replaced head gasket in 1st place as there was a big leak comming from head gasket & the fluid was running down into the clutch housing. Would this cause the clutch to slip?
at the mo when i give a fast flip of the throttle you can hear the weird noise which i guess is the clutch slipping, when i go slow its fine.
I tried cleaning the clutch area with cotton buds & dry cloth etc & alot of black soot kind of dust came out, but it still seems to be slipping, whats the best method of cleaning it
