RCU Forums - View Single Post - R149DP Issues?
Old 08-09-2006 | 04:23 PM
1Eye's Avatar
1Eye
Default RE: R149DP Issues?
Bax replied . . .
... must not compress the foam, otherwise the purpose of the foam as a vibration-isolator is ruined.
Yep, I got all that, Bax - vibration will kill the IF filter(s) in short order. Your other points/observations are certainly valid wrt issues stemming from, ah let's say, less than optimum installation practices. Clearly, the larger airframe, big gasser powered airframes can be a real challenge in terms of vibration. There are several 149s in use within our club and no actual rcvr failures reported. All my 149s are flown in jets - both d/f and turbine - with a lot of hours on each airframe and the rcvrs have been rock solid.
Don't misunderstand me, I'm not trying to cast dispersions on a great product - just wanted some feedback from the horse's mouth and you've been very helpful. Thanks for the reply.
Mike
