The air cleaner will work fine, and keep a lot of the carb mist off the engine.
You do not need, nor will it help to use an idle bar plug in that engine. Use
a K&B 1L plug in it.
You can seal the exhaust manifold to the engine with some high temp
silicon seal, and that will keep the engine cleaner as well.
FBD.
