RE: how many turns
How did you clean the one way shaft? Did you remove the pull start and just wipe it down. I'm also having a hard time starting my Vulcan SE after being broken in.
Well you have to take the engine out, then you remove the pull start, once you take it out remove the one way bearing inside the pull start and what I did is I cleaned it with Denatured alcohol make sure you re-install it the way you took it off, and you should be fine.
