RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 08-10-2006 | 09:02 PM
  #2378
Neurotex's Avatar
Neurotex
Default RE: Air Hogs Aero Ace!
ORIGINAL: MegaByte-2
Neurotex
Sounds like you have a handful. Higher winged planes are more stable as the weight below acts somewhat like a stable pendulum. That may help alot. Ever think abt undercambering the canard? It would hold way more lift at slow speeds.
The new design will have an undercambered canard. Maybe these changes
will help.
ORIGINAL: novielo
neurotex, is with your "spring wing" plane you got trouble with? did you try stop, by some way, the spring? maybe it's because your wing move in a unwanted way??
I ended up removing the spring & trying different wing angles. Didn't help
it one bit. I hope to still use that thrust spring.
(I should move this back to micro's AA/X-Twin thread)
