RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 08-10-2006 | 09:06 PM
  #5153
Blisster's Avatar
Blisster
Default RE: U-Can-Do 3d 46?
ORIGINAL: torombolo
I want to go the ST way since more economic than OS, I know (DON'T BE CHEAP) Those $60.00 could be 2 servos.
Will wait on your post. I might order mine tomorrow.
You're totally right, $60 is $60, do what you need to do and know that Super Tiger makes some very good and powerful engines! For the money they are some of the best engines around! As long as you keep using your head as well as your wallet for these decisions you can't go wrong! You'll enjoy the plane knowing you did it the way you chose! I wish you nothing but success!! Still, reinforce the landing gear block, it is almost a "must do" upgrade. Drill two holes through from the wing saddle opening to the exhaust ramp just inside the dowels, fill it in with glass and while still wet, lay in two 4-40 rods to hold it all together. Here are some reposts of gear reinforcing jobs (Thank gjeffers and raideron for these pics!!) Hope it helps clear you up on what you need to do here. Enjoy the plane!
Bliss
ID:	505359   Click image for larger version
