RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 08-10-2006 | 09:40 PM
  #2381
FERNDALE AIR FORCE's Avatar
FERNDALE AIR FORCE
Default RE: Air Hogs Aero Ace!
Gtx, is that an entire lower wing glued on under the main wing?
Here are dreadful sketches of the cg finder I'm going to build. I'm going to take 1/8" ss, put a pair of rods parallel at 37.5 degrees, they will be attached to a base of some sort, or triangulated. This should allow me to put the airplane on the rods to determine CG. I think what was described in earlier post was a way to find center of mass. I had not thought of that before. Please note, the crappy drawings I made are very similar to what I get when I'm building prototypes or custom products. I guess I've learned to decode these things, and in the meantime am now used to drawing this way. Tim
