Header tank
Header tank on a pumped engine???
How would you benefit here? I might be way off base but it seems to me that if you have no external pressure going to the rear tank, e.g., from the muffler, how do you keep the header tank from emptying before the rear tank? Since tanks require venting you wouldn't benefit from a syphoning or bladder effect a closed system would give you.
