RCU Forums - View Single Post - Header tank
Thread: Header tank
Old 01-07-2003 | 12:52 AM
captinjohn
Default engines
K_Hunt: You may also have an airleak in intake area... that gets worse as engine warms up after running. You can check by blocking off carb and exhaust..... then apply 1/2 -1 lb air pressure. Use soapy water to check all gaskets, seals anywhere you think it could leak. Do not over pressure, or you will blow the seal out around propshaft. CaptinJohn
