RCU Forums - View Single Post - Tamiya Pershing roadwheel problem
Old 08-11-2006 | 01:10 AM
Planedev
Default RE: Tamiya Pershing roadwheel problem
Yes I got some bearings from a bearing distributor locally. So you are sayingthat the bearing oil of the after market bearings causing this problem? If so I shld go back to using the original bushings that came with the tank? How abt the rumour that the grease tamiya supplies for the bushing points also cause a similar problem is this true or false? Thank you
