RE: MPI clutch springs
The actual lengh of the stock spring is 1 and 13/16 inches long. The spring you have you will have to cut then bend the loops in. The measurement of the stock spring is from the end of the loops. Subtract 2/16 of an inch for the inside lengh of the spring. Hope this helps.
