torombolo.... This is just what I saw from the above engines at my field, they all ran
great from the get go.... It's just the S.T. "at our field" would be the last one on my
list.... Price/power they are all pretty close.... At our field when members have a
problem, (as I'm sure at all fields) all will try and work out the problem... So it's my
belief, that tuning error is a bit less for the cause of the problems... But there are a
lot of factors that causes problems.... So for "me" what I have seen would be "my"
deciding factor... But as always that can change
In this day and age... I really think all, makes good equipment... It's just for what
ever reason "to some" the rating differ.... As you said, Get all the info you can to
help make your decision... But it's hard not to go with your info if you could see it
put to the test where your flying... And to me beside cost, what people use where
ever you will be flying should also be a thought........ Good luck on your choice!!
