CAP 232 40 engine?
Ailerons are about 5cm/2'' wide, and little longer than originals. Very near the real CAP's dimensions. I had to made some changes to the wing: I moved trailing edge forward and I made new ailerons from foam what is laminated whit balsa. I made new wing strip next to R-4 and aileron servo is between these two ribs.
Saito FA-100 isn't so heavy but it would have so much power that CAP can't use all of it ever.
