RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 08-12-2006 | 11:14 AM
  #2402
Neurotex's Avatar
Neurotex
Default RE: Air Hogs Aero Ace!
After making some glider tests it flys much better with the canard
above the wing. Moving it at the fuselage joint changes the CG and
moving it at the canard joint changes the lift.
It doesn't take but a few degrees one way or another to cause a drastic
difference in the way it flys. Now I have factor in thrust from the motors
and motor angle, which no doubt, will change everything again.
