rtn9105.... Yea, the 100 and bigger prop puts a lot of air on those bigger
surfaces that are now moving a bit faster with holding power a bit stronger..
Think of "Do" #2 as a different plane... Able to do all that you use to do,
but with this one once you get it setup and get the feel for.. You won't go
back!!! Do what barry said about dual rates... I use 20-30 with about 70%
expo on low and 70-85 expo on hi.... And the other is that left stick, not
only keeping it on the low end... But sometimes just breathing on it is
enough
Had a Good morning at the field, even tho I only took the S.T..... I did have
a bit of a scare[:@]... Guess I was having too much fun, and on top of that I
went out a bit further on my apporch for my landing.... And the Too much
fun added up to not enough fuel... (Not that again)... I was wondering if it
was going to make it back to the field after that prop stopped[:'(]... But she
did almost like a "Do".... Well maybe not... But she came in great with no
problem she was about 5' short of the runway, but made a smooth landing
on the dirt... [8D] OK it's time to land.... No.... Land [8D]
If I remember correctly I think I added 2ea. on the two bolts.. I did it a few
times... And my memory is fading, so not really sure what I ended up with...
