RCU Forums - View Single Post - voltmeter/load help
Old 08-12-2006 | 03:50 PM
jeff1127
Default RE: voltmeter/load help
You could always measure the battery in the plane with all the servos attached. Use an unused channel and attach an extension to plug your meter into, or a Y cable. This is the way it's done with the on board metering devices.That way you are measuring the battery with exact load placed upon it.
