RCU Forums - View Single Post - Substitute for Ether
Old 08-12-2006 | 06:43 PM
  #120
Stuntguy13
Default RE: Substitute for Ether
Greg,
The castor will not normally mix with either lamp oil or kero, the thing that gets it to mix and stay in solution is the ether. Ether is a very strong solvent, without it we need to use a synthetic oil or mineral based oil. If you still have the mix you made up put in 35% JD and it should mix just fine.
