RE: Engine Tuneing Tips . . .
Cyclic is correct. I tune all of my motors with the pinch method.
I also pinch the fuel line on the high end. Tune it so when I pinch the high end, the motor accelerates a bit. if it does not accelerate, the high end is to lean. Use a tach for perfection. Some motors with a pipe are hard to hear the change in RPM.
