ORIGINAL: paulino966
thanks for the input,what i ment was i tightened the nut on the spur gear all the way.i do not back it off,i own the savage x and i mesh the spur good and i tightened the motor mounts srews tight and also my spur gear is wobbly.my transmission case cames apart from the top,i think that might be a weak point...
Yes if you have stripped the screws holding the top of the case this is a problem from what I have read. All so I do not know how true it is but someone said HPI is coming out with a new X transmission case. I am so glade I have the older Savage from what I have read. I hate to hear about the X as I am a HPI person! With many gallons on mine I have had very little problems and run the same spur for well over 3 gallons.
