RCU Forums - View Single Post - Engine tuning
Old 08-13-2006 | 01:46 PM
Cyclic Hardover's Avatar
Cyclic Hardover
Default RE: Engine tuning
ORIGINAL: bkdavy
To check your idle mixture, start the engine, then at full throttle, adjust the high speed valve to peak RPM less 300-500 rpm to the rich side. Now reduce throttle to your lowest reliable idle. Let the engine idle for about 30 seconds, then punch the throttle to full. If the engine hesitates, then goes to full throttle, the low speed mixture is rich. If it goes to full throttle without hesitation, your done. If it just dies, your low end is lean. An alternative check is to pinch the fuel line. If there is a slight rise in RPM when you pinch it, your rich. If it dies immediately your lean. If it continues to run for a few seconds without RPM rising, your close. Use both tests.
Now based on your results, you can make a small adjustment in your low end needle. Remember with an airbleed carb, turning the screw out will LEAN the mixture, and vice versa. Make your adjustments in 1/8 turn increments. Then you MUST reset the high speed needle as before and repeat.
Take your time. It might take a few tries to get it dialed in, but once you get it, you'll never have to mess with it again.
Good Luck.
Brad
Even by doing this your idle mixture can still be way way off which is what I see all the time.
