RE: first conversion
andrew
most guys open up the reed valve limiter so a 1\8 inch allen will fit between the limiter and the valve for a little more intake flow its not that critical of a modification . read the back articles in this forum there is a lot of info on what to do for the ryobi ,its usually pretty good stock depending on wich one you get.
