RCU Forums - View Single Post - 9C Link Issue -> Bug
Old 08-14-2006 | 11:03 AM
Bax
Default RE: 9C Link Issue -> Bug
You'll have to put the throttle->rudder mix before the rudder->aux mix (for dual rudder servos) to get the throttle->rudder mix to link properly to both servos. That works. If you put the throttle->rudder mix on a switch, then you can turn it off when you want.
