Thank you I will try it tonight.
I use a throttle down switch for landing and place
the mix on that switch so it is off at throttle down.
ORIGINAL: Bax
You'll have to put the throttle->rudder mix before the rudder->aux mix (for dual rudder servos) to get the throttle->rudder mix to link properly to both servos. That works. If you put the throttle->rudder mix on a switch, then you can turn it off when you want.
