RCU Forums - View Single Post - prop nut
Thread: prop nut
Old 01-06-2003 | 04:16 AM
Whirley Bird
Default prop nut
Originally posted by downunder
I .
Tightening the nut puts the prop hub under enormous compression loads and if you overdo it then the hub could eventually fail.
Hi Downunder,
Well,
After I had to tighten mine only one time,
I realy cranked down tight the second time.
Never used any lock-tight and it's still OK but when it does turn on me again when I check it for looseness then i'll just replace it.
Thanks for the info
