RE: cooling problem maybe??
the best material for a baffle is the carbon fiber laminated sheet . less than 1mm thick , very easy to use and lasts a long time . make a template from cardboard , repilcate it and u can first tack it with cayno , then run a bead with epoxy/ milled fiberglass mix. done
