RCU Forums - View Single Post - CMPro Swallow EX 90
Old 08-15-2006 | 09:55 AM
BaldEagel's Avatar
BaldEagel
Default RE: CMPro Swallow EX 90
Haisan
I installed one washer under each bolt on one T engine support as per the instruction manual to give side thrust, I have not found the neccesaity for any down thrust, but I have not finnished trimming the model yet.
In the instructions it says install 4mm washer, thats dia not thickness just to be clear, the washers I used where the ones in the box.
Hope this helps.
Mike
