RE: Rounding the wing tips
When I carve a wing tip out of balsa I will usually take a router bit on my Dremel and hollow out as much of the inside of the block that I can. I do this to cut down on weight. Try to make sure that the weight of both wing tips is close so it doesn't throw the lateral balance of the plane off too much.
Ken
