RCU Forums - View Single Post - Is this enough engine cooling?
Old 08-15-2006 | 09:49 PM
Campy's Avatar
Campy
Default RE: Is this enough engine cooling?
For PROPER cooling you should use a 3:1 ratio. For every square inch of air inlet, you should have 3 square inches of air outlet. Depending on how cold it is outside when you fly, you MAY be able to get away with a 2:1 ratio. I wouldn't use this ratio for summer flying since the chance of overheating is greatly increased.
