RCU Forums - View Single Post - Balancing
Thread: Balancing
Old 08-16-2006 | 07:50 AM
bruce88123
Default RE: Balancing
ORIGINAL: mcoccia
Thank you
Do I add the weight to the Lighter Wing itself or the fuse?
If possible add it as far out on the wing tip as you can. This way it will take less weight to achieve the balance. This in one reason to do a preliminary balance when building a kit BEFORE covering. Fully assemble the plane (remember the muffler) except for the covering and balance so you will have full access for adding weight. Usually you will not have to add additional weight after covering, at least not laterally unless you go wild with decals.
