RCU Forums - View Single Post - need color advice
Thread
need color advice
08-16-2006 | 09:08 AM
3
MinnFlyer
My Feedback: (
4
Apr 2002
28,519
Willmar, MN
RE: need color advice
Contrary to popular belief, you don't need bright colors. What you need is good contrast, and there is no better contrast than B&W.
Now, having said that, a Checkerboard does not give a good contrast due to the fact that the squares are small. At a distance, they will appear gray.
By the same token, an all-black fuse can worsen the "Silhouette" effect.
So if you want to stick with B&W, that's fine, but maybe add a black band to the LE of the wing on the bottom, and a B&W Sunburst on top - Then some white along side the Fuse would be a plus.
One other thing worth mentioning... If you have a lot of trees or mountains in the background (Or anything else that is dark) Black will just about disappear when the plane is between you and the background
Reply
Like
MinnFlyer
View Public Profile
Send a private message to MinnFlyer
Find More Posts by MinnFlyer
View iTrader Profile
