RCU Forums - View Single Post - Planes Plus Dream 110 conversion
Old 08-16-2006 | 11:01 AM
  #43
Mike Parsons's Avatar
Mike Parsons
Default RE: Planes Plus Dream 110 conversion
ORIGINAL: team3d
MIKE PARSONS,
Did you do any programming with the Castle Creation Phoniex 80 so it can be used for the plane
and the motor or is there no programming?? Also if I use the Phoniex 60 ESC do you think that I
will fry the ESC or do you think I will be Fine??
Team3d
The only change I made in the Controller was for Cut-off Voltage. Everything else was left default.
The 60 will handle the load fine. It has a burst rating that well covers what the power 60 will produce. I have found that most of my flying is done right at 35 amps. I dont rise above that unless going vertical and using full throttle.
-Mike
