RCU Forums - View Single Post - Castle HV-85 settings help needed
Old 08-16-2006 | 05:34 PM
KeithB's Avatar
KeithB
Default Castle HV-85 settings help needed
I just purchased a Castle HV-85 to try out with my Hacker C50 and I have questions regarding the following settings:
Setting 3: I don’t understand how the breaking works. From what I’ve heard on this forum there breaking that slows the prop speed for down-lines, but I can’t tell which settings cause the prop to come to a full stop and which will apply the breaking we need in pattern.
Setting 4: What throttle setting should I use?
Setting 5: What timing? I assume Low advance timing (option 3) since the Hacker motors use 0 to 5 degrees.
Setting 7: Soft start setting? I assume option 2, Soft Start.
Setting 8 PWM Switch Rate: 13khz?
Thanks for your assistance,
Keith B
