RE: Up thrust instead of down thrust???
I'll try the dive, but my guess it would continue the dive and not pull up. When I first read your reply I thought you said that if it dropped off on a turn, and boy this plane does. To steep of a turn and it falls right off. thanks for the help.
If it was the top wing incidence, how would I change that, by changing the bottom wing? Top wing is soldered wire and would be difficult to alter. thanks
