ORIGINAL: novielo
IT'S ALIVE!!!!!!!!
i just made the fet mod on a aa jet... and it works.
Congrats!
Sounds like you have the N20's but a pic would sure help.
The jet didn't fly very well as a tractor set up (too tail heavy) but flew
great as a pusher with the Defender props. (minus the huge plastic nuts)
The CG was about an inch behind the cockpit. But since you have a heavier
battery I'm not sure where it is now. Try gliding it close to the ground in
thick grass. Some tail trimming may be needed too, as you can see I
bent it up pretty good back there.
