RCU Forums - View Single Post - Cap 232 elevator u link
Old 08-16-2006 | 10:14 PM
gbfan
Default Cap 232 elevator u link
Hey Guys
I got a overseas cap 232 with crap for directions 1/4 scale ... It has a 2 piece
elevator with a metal u link between them. I want to run this on one servo.
Is this a safe way to do this? I drilled the holes in the elevator and
installed the metal u link.
I epoxied the hole assembly but I have not seen this set up before.
There is a servo mount on the other side for the rudder.
I know I can use a pull pull rudder and take advantage
of the that hole and do a 2 servo
elevator but I would like to keep things simple.
Then I would have to reverse that servo
to much work Will one servo work ?????????/
I am using hi torque futaba servos
in this application. S3010s
David
