RCU Forums - View Single Post - Ultra Stik 60 Question
Old 02-12-2003 | 07:16 PM
Cheech's Avatar
Cheech
My Feedback: (19)
Default Ultra Stik 60 Question
So it seems I may not be well served by the stock wheels. I have heard they're too small. I may want a pair of bigger ones anyway if for nothing else than to gain a little clearance for my 15" prop.
And yes, rcpilot44, my elevator linkage is ball linkes at both ends . It is a very slop free, easy moving setup. I hardened the servo mount areas on the back with lite ply. Under the rudder servo I did a full little servo tray, covered then epoxied externally to the fuselage. On the elevator I put some lite ply on the INSIDE, behind the servo screws. It's a solid setup.
Again, I am REALLY REALLY glad I mounted the servos in the back. Even with those two servo's and all the hardware I STILL had to shove my battery way back in the radio compartment just to get close to balancing. It's a nose heavy plane. With the 100 this plane would need lotsa tail weight to come out close. I may still add an ounce to the back. To those that are actually FLYING your STIKs, where are you CG'd? I'm at about 4" now.
I guess I'll put a little fiberglass on the landing gear block also. I gussetted it in with some additional balsa tri stock, but the glass wouldn't hurt.
