RCU Forums - View Single Post - Ultra Stik 60 Question
Old 02-13-2003 | 07:15 PM
hilleyja
Default Ultra Stik 60 Question
I have a full season under my belt with this airplane and have had no servo related problems with it.
Elevator: Hitec HS-605
Rudder: Hitec HS-605
Throttle: Hitec HS-422
Airlons: (2) Hitech HS-425s
Battery -- generic NIMH 1500mah, with Hitec switch.
I have also had no problems with the standard tail wheel that came with the package.
DO: pin CA hinges (all I did was use a trimmed common pin and a drop of CA for each hinge half)
DO: re-enforce main landing gear block (you need to strengthen the block itself, not just where it is mounted to the fuselage)
DO: adjust CG to specs.
DO: setup QUAD flaps -- this plane is king with CROW
