RE: Epoxy or Gorilla Glue
Gorilla glue does not attack the foam like CA does and is lighter than epoxy. The big diadvantage other than the expansion is the long dry time. If you are not used to using gorilla glue, you can lose parts alignment when the glue expands. When using gorilla glue, if it looks like you have enough glue on the part, you have too much. Use as little as possible to avoid the expansion problems.
