ORIGINAL: STG
You cannot expect to keep the throttle in one position and keep the plane at a constant speed as you are going thru a large loop. Do you mean that you are not increasing your throttle when you are climbing and not decreasing your throttle when descending?
No what i mean is that even when increasing power the plane seems to gain too much speed vs pull. I need more "bite"
How heavy is your Edge and what does your 1.08 turn your 15x6? It should pull very well if the plane is only around 8-9 pounds.
came in about 8.8lbs
I will get a few props and see how it works out.
