RCU Forums - View Single Post - Fancy a FunFactor 6061 ARO chassis?
Old 08-17-2006 | 06:38 PM
  #80
dustin7837
Default RE: Fancy a FunFactor 6061 ARO chassis?
I'm searching up ebay a bit every day to see what I can get for cheap. I am starting college again in 2 weeks so funding is limited. probabaly .21-.28 range. I see STS has a nice .30 5 port out now though...
I think I can run genesis spurs wtih 14/17s to start, then i will up the pinions if necessary. I already have all cen's hop ups on my rally except hardened diffs, but I am bidding on a magnum chassis and shafts right now on ebay. I just ordered CT5 mounts from customrccars.
My only concern is that I ma going to twist those puny driveshafts right off first time I press the throttle...
I am going to start ordering some random shafts off ebay, whatever's cheap and finding something that will work... even if I need to cut em shorter and install a new pin.
I always wanted a touring car, but don't have enough good pavement nearby and couldn't be bothered with worrying about belts and little pebbles and foam tires. SO this should be the next best thing.
(check my gallery and "my models" for my current rally setup)
