RE: Using a RotoZip bit in a Dremel for shaping a stack of ribs?
What do you hold onto?
A table mounted Dremel with the rib stack pushed past the stationary tool is safest
Should be OK with taking pains to keep the Roto-Zip from taking off thru the rib stack.
