RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 08-17-2006 | 10:39 PM
  #2460
FERNDALE AIR FORCE's Avatar
FERNDALE AIR FORCE
Default RE: Air Hogs Aero Ace!
Gtx, what is 1c?
Djstinger, the heat that is created by a lipo destruction, as described by GTX, is equal to willie pete. I am not old enough, nor young enough to see WP in action. I have had training in how to deal with it. Dj if you overcharge or use an untested charging device. Your home could easily burn down. If you live in an apartment structure, it will burn down. Please follow the charging instructions for your model. Please do not mix chargers. I'll try to go back and find the pic's of homes burned out due to improper charging of LiPOs. I lost my train of thought there, GTX says the heat from a lipo is 2000 degrees. A fire in the fireplace is less than 600 degrees, when you light a piece of paper it is 460 degrees. My forge is about 1500 degrees, that is for forming steel. My Plasma Cutter may get to the 2000 degree level, but it is a controled operation. If I sound to strident about being careful I apologize.
