RCU Forums - View Single Post - Using a RotoZip bit in a Dremel for shaping a stack of ribs?
Old 08-18-2006 | 03:01 AM
SMUGator's Avatar
SMUGator
Default RE: Using a RotoZip bit in a Dremel for shaping a stack of ribs?
It only takes 5-6 minutes to shape a stack of 8-10 ribs sandwiched between 2 formica templates using a combination of razor plane, sanding blocks and files. If you want to buy a new tool or practice a new technique, don't let me discourage you. But hand works is as good as machining for this process.
Tom
