RE: Fancy a FunFactor 6061 ARO chassis?
Ah yes Rolland, but you wanted it wider, not longer if I remember rightly! Lol, nevermind, whatever happens DrH will come up with something a whole load better than stock for sure. Besides, shorter means lighter. Oh, and I think hes using the drawings I did of my JT chassis, so you will get a whole 7mm of extra length! (Yes the stock centre shaft can cope with the 7mm, before anyone asks!)
Dustin - the Genesis spurs are 43t and 39t, so you want the Cen steel 14/18 bell mate not the 14/17. Mind you... Im sure you will be after taller ratios pretty quickly!
How about an Ofna 2 speed? Then you could swap between that and a centre diff. Watch it though, as I type I remember that the Ofna setup isnt offset to one side like the Cen brake seat, so engine plate mount clearance and flywheel clearance might well be an issue if you choose that route. No idea at all about the Genesis parts Im afraid, but good luck whatever mate, it sounds fun.
