RCU Forums - View Single Post - EVO- Engines
Thread: EVO- Engines
Old 08-18-2006 | 09:48 AM
joenella
Default RE: EVO- Engines
Hi Radar.
That's bad news for me, do you have smoke pump and tank onboard or nothing at all?
I plan to use full pipes that will go behind CG , 1 receiver in back for the servoes with lipo supply, cables for servos fiberoptic.
Have you used the fiberglass plate in the front on the plane, you can save 1 kg by using balsa wood instead, which material has been use for covering?
I must have it down under 25 kg's inc fuel, by the way fueltank size? 1 or 1,5 l?
brgds
Joen
